Return GUID from SQL server 7
Hello there,
I need to extract a GUID from my SQL server 7 database. I'm using the SQL toolkit version 5.0 with Labview 6. I can extract all the data types except for my GUID which is a uniqueidentifier data type. When I try to extract a GUID, I get error 4149 "Fetch Next Record - [Microsoft][ODBC Driver Manager] Program type out of range". I'm not using any Unicode data types. For example one of my 16 bit GUIDs looks like " {6F4CD9C5-43D9-4BB4-92C2-772F41FE3004} ". Is this a problem that is solved by upgrading to the DCT? (Database Connectivity Toolkit)
Nathan
(3,964 Views)
This problem is a SQL Toolkit problem...
A workaround:
SELECT UPPER(guid) FROM [table]
This way SQLServer will return the results in string format.
Wiebe.
"tqs engineer" wrote in message
news:5065000000080000007A310000-1005954886000@exchange.ni.com...
> Hello there,
roblem
> Toolkit)
> Thanks,
> Nathan
(3,964 Views)
Works like a charm.
Thanks much,
Nathan
by the way, they are 16 byte GUIDs
(3,964 Views)
