Returning filenames numerically
Hi All,
I have a large number of files that I need to pull the data from and stitch it together, I have an idea of how I can do this but the "List Folder.vi" that I was intending to use returns the filenames alphabetically giving me an array of file names in the following format:
1-xxxx, 10-xxx, 100-xxx, 2-xxxx, 20-xxx and so on.
I can't quite get my head around how I can re-sort the array so that irrelevent of the number of files in the  folder I always get the array in numerical order.
Any help?!
Cheers,
Dom
(3,665 Views)
Accepted by topic author DominicRoberton
Hi Dom,
something like shown in the attached image should work for you.
Mike
(3,662 Views)
Cheers for that,
I am not going to lie though the input string you used looks basically a bit like magic to me!!!  Can you show me how I would modify it to take care of files using the following naming system:
1-ER-Data
1-SS-Data
1-SS-GPSData
1-SS-UTCTime
Many thanks.
Dom
(3,652 Views)
Actually I should have just tried what you put up before asking!!!
Thanks, it works 🙂
Any chance you can explain to me how it works?  Particularly why you input the magical numbers text string you did!!!
Cheers,
Dom
(3,646 Views)
Hi Dom,
the "magic" string cuts the filename into extension and name without extension.
Mike
(3,643 Views)
