Reverse Engineering G -> State Chart
I heard of a tool, which can produce from a State Chart a block diagram.
I'm searching for a tool which makes the opposite. Does anybody knows a tool to create a from a Block Diagram a State Chart?
(2,861 Views)
I believe you are refering to the State Diagram Editor. NI LabVIEW State Diagram Toolkit With the toolkit you draw the various nodes and connections, and the diagram is built for you. All you have to do is insert the code you want in each state and some simle deciding on which state to go to next and you are done. I have used it and I thought it was great. It even adds and removes states as you change the chart.
(2,861 Views)
