Reverse of "Format Date/Time String.VI"
I'm looking for a VI that does the reverse job of the
Format Date/Time String, i.e. converts a string with a date
and a time, and with an time format-string input that describes
the format of the string, and gives a time stamp as output.
Anybody done this one ?
Martin
(3,884 Views)
Very simple; just wire the string to a scan from string function and extract the month, day, year, hours, minutes and seconds as separate numbers.
Now the date/time to seconds function takes a cluster of these numbers and converts it to a timestamp so all you need is to bundle the numbers into that cluster and give it to the date to seconds function.
(3,884 Views)
This is of course assuming you have a particular known format of the time and date string to be converted. Otherwise different time display formats can mess with the conversion,
is 01/02/03 the 1st of February 2003 or the 2nd of January 2003? Dependson whether you live in the USA or not I guess...... Not to mention that the days and months can be spelled differently in different languages if you have a verbose time/date string to convert.
Just my thoughts on the subject.
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(3,884 Views)
Building that cluster requires that you enter which day of the year it is. As far as I can tell labview doesn't have a vi for that.
(3,884 Views)
No, it doesn't. If you check the online help for Date/Time to Seconds it clearly states that 'day of year' is ignored.
(3,884 Views)
