Reverse the set of 2D array
Hello everyone
I have 2D array as below , i need to reverse the array by the group of 3 rows
1 1 1 1 1
2 2 2 2 2
3 3 3 3 3
4 4 4 4 4
5 5 5 5 5
6 6 6 6 6
7 7 7 7 7
8 8 8 8 8
9 9 9 9 9
So the result shoud be
7 7 7 7 7
8 8 8 8 8
9 9 9 9 9
4 4 4 4 4
5 5 5 5 5
6 6 6 6 6
1 1 1 1 1
2 2 2 2 2
3 3 3 3 3
how can i do? please suggest me thank you!!!
(3,765 Views)
Hi midori,
straight-forward:
(3,761 Views)
Thanks for your help GerdW
How can i make the result to 2D array ?
(3,751 Views)
Hi midori,
right-click the BuildArray node and select "concatenate elements"...
(3,749 Views)
This is one of the approach it will convert any number of elements in the array.
good luck
(3,738 Views)
It works very well
Thanks a lot !!!!
(3,734 Views)
