Reversing a 2D array
How can you do this
| 1 2 3 4 |
| 1 2 3 4 |   =====>
| 1 2 3 4 |
| 1 2 3 4 |
(6,672 Views)
Could you please also show your desired outcome? The implementation will differ depending on if you want to reverse only the rows, the columns, or both.
(6,663 Views)
Hi I posted it in the previous mail but here it is again.
Sorry i pressed Enter twice by mistake
How can you do this
Im reading 4 values at a time and want to store them in a 2 D array
                                | 1 1 1 1 |                  |   4 4 4 4 |
                                | 2 2 2 2 |   =====>  |  3  3 3 3 |
                                | 3 3 3 3 |                  |   2 2 2 2 |
                                | 4 4 4 4 |                  |   1 1 1 1 |
Here is my VI.
(6,658 Views)
Your example is not very good, because all columns are the same. We do not know if the rows got reversed or not
A simple example to only reverse each column is attached, there are many ways to do this.
(6,654 Views)
Cool , that worked !! Thanks didn't know you could do that with a for loop.
GM
(6,645 Views)
