Review
Accepted by topic author ali9963
@jamiva wrote:
@altenbach wrote:
(Disclaimer: Not fully tested. Please verify correct operation. There might be bugs)
ali996
One minor bug I see is seconds is 2 x sssss
Thanks, that's of course easy to correct. I am  on a 14" 1080p laptop and that thing still looks like a "+" to me :o. They should have written it as "sssss = seconds/2" or "sssss = seconds * 0.5". 😄 A division makes definitely much more sense. (I was actually puzzled by the +2 and thought that it might adjust for some internal delays, e.g. between getting time and getting data 🐵
Message 11 of 18
(1,829 Views)
can you please check the second vi
Message 12 of 18
(1,817 Views)
Please quote relevant parts of the post you are replying to. We don't know who "you" is, what "check" means, and which vi you are talking about.
Message 13 of 18
(1,810 Views)
Hi
am not getting how to move forward from the below statement.
Message 14 of 18
(1,776 Views)
No need for any explicit matrix operations. All you need is general polynomial fit.
(or you could use general linear fit and set up the H matrix explicitly, but you are using all terms of a second order polynomial so this is not needed. See also my recent presentation).
The scaling by integer powers of two will depend on the obtained raw coefficients. Do you have an example that contains actual data?
Message 15 of 18
(1,769 Views)
No,
i don't have an example that contains actual data, actually this is an assignment given by my senior,
actually i am new to LabVIEW, so i was looking for suggestions.
Message 16 of 18
(1,760 Views)
I made suggestions in the previous post. Have you tried them? 😄
(I don't understand the scaling, because the range makes little sense. For example if one coefficient is zero, no multiplication with powers of two can make it 16384. I suspect that the result should actually be scaled to a signed integer (or FXP) of a certain bit count. Do you have more information on this?)
Message 17 of 18
(1,751 Views)
i will ask my senior about this info. yes i was going through your suggestions.
Thanks for helping
Message 18 of 18
(1,748 Views)
