Rich text box instances memory eaters?
This vi is eating lots of memory. Are the richtextbox objects used right?
(3,034 Views)
Do you mean disk memory? The pasted pictures are taking close to 80% of the disk space (file size).
Richard
(3,021 Views)
Why are you using RichTextBoxes? All that they seems to be displaying is a simple OK and Cancel message. A simple string indicator can do the same thing. Even with the RichTextBoxes, why are you setting the Font and text in each iteration of the loop?
(3,019 Views)
Tnx guys.
I found the problem. I was registering user events in my 'while loop'. I think they got stacked up in memory.
The strange thing with rich text boxes is, after u set a text value, it disappears
(2,997 Views)
I still don't understand why you're using RichTextBoxes.
(2,991 Views)
I think I fancy them. But I know it's better strategy to use LV objects.
(2,987 Views)
