RichTextItem in Lotis Notes
Has anyone successfully attached a document to a Lotus Notes email? I'm having some issues, as you can see with the diagram.
A newbie to Labivew 2009...sure could get some pointers!!
(4,094 Views)
Please stick to your original thread so others don't rehash the same questions or give you suggestions that have already been proposed. You never answered Logan's question.
(4,082 Views)
I did have a problem with Lotus notes sending an attachment but i finally got it working.
I could send the attachment succesfully but my problem was that i could not open the attachment.
What is your problem? I can't open your VI i have LV8.6. Which diagram?
(4,057 Views)
I do not know where to add the RichTextItem within the Case Structure. If I omit the RTI, the email sends with the way I have it working now.
(4,055 Views)
Not very clear....sorry. The email sends if I remove the Rich Text Item entirely. My problem is I don't know where the Rich Text Item fits in to the diagram I have.
(4,053 Views)
Old thread revival time!
OK, now that I've had some time and done a little investigation...
When you wire the Document Class, one of the items you'll see is CreateRichTextItem. Select this and wire this to another Invoke Note..this should bring up the RichText Item Class. Select Embed Object and go from there. The attached VI will explain what I'm doing and hope not confuse you even more.
I noticed that my two posts were merged about the RichText and the SendTo item, so I'll continue with the way Lotus Notes likes to send.
In VBA (since this is all I have as a text based language), I can send a email by using the Send Method if I declare my SendTo recipients eariler in my code. Like this:
Sub TestLotusNotes()
Dim s As New NotesSession, dir As NotesDbDirectory, db As NotesDatabase, doc As NotesDocument
s.Initialize
Set dir = s.GetDbDirectory("")
Set db = dir.OpenMailDatabase
Set doc = db.CreateDocument
With doc
    .ReplaceItemValue "SendTo", "John Doe"
    .ReplaceItemValue "Subject", "Hi"
    .ReplaceItemValue "Body", "This is a test."
    .SaveMessageOnSend = True
    .Send False
End With
Set doc = Nothing
Set db = Nothing
Set dir = Nothing
Set ses = Nothing
End Sub
Now, if I wire this in Labview the same way I have it written in my VBA code, it fails when I try to send the email. I get a Error -2147217264 from Lotus Notes. I've noticed that if I place my "To" string to the optional recipients spot, it works. Hmmm....
I'm still trying to investigate, but I wondered if anyone else has ran into this problem and gotten this to work without resorting to wiring the SendTo item to the recipients area.
(3,832 Views)
