Right Toggle is not moving motor
Recently, we have got all of our LabView set up so we can move our motors with out left toggle stick on our xbox controller, but for some reason our right controller isnt working. On the driver station where it shows you all the axis's and what each toggle or button does, it reacts when we use the right toggle so its connecting to the driver station, just not to the robot. Below I attached our Before.vi Teleop.vi and PerodicTasks.vi.
(3,286 Views)
Surely you can post the actual VI or an image that does not come from your phone.
All I can see is a bunch of isolated functions. There does not seem to be any structure at all.
(3,254 Views)
Please include a Snippet of your code, or attach your VIs, so that we can better assist you. We are here to help, but won't spend all day recreating your code from scratch.
You have nothing USB 0 wired in to both joystick VIs. Could that be the problem? I would guess you can only use that single USB port for one or the other.
Cheers
(3,246 Views)
You're not using the "run continuously" button, are you?
Bill
CLD
(Mid-Level minion.)
(3,221 Views)
Thorbots,
This forum could be really helpful but if you are on an FRC team competing this season, this could be helpful too:
https://decibel.ni.com/content/community/academic/student_competitions/frc?view=discussions
You could also call into FRC technical support from 1pm-7pm central time
Becca B.
Product Marketing
(3,158 Views)
