Right-angle wire within In Place Element Structure?
A small oddity: if you drop a primitive too close to the top or bottom edge of an In Place Element Structure, the suggested wiring route goes at right angle (where it does not belong).
Example 1:
Example 2:
There is supposed to be a dashed horizontal wire from the index array primitive on the picture above, but my screen capture software did not grab it.
Tested in LV 2011
(2,519 Views)
I see what you mean.  It doesn't seem to cause any harm.  Just an oddity in the drawing of that potential wire route.
(2,512 Views)
