Rightclick on graph not possible to select "visible items"
i have a problem with a graph. I use the same type of graph in two different projects.
But only in one project i can rightclick on the graph which shows a popup to set for example "visible items" where i can show/hide the cursor-legend.
Is there any mode that prevents a rightclick on the graph?
I can only change the visible items when the program is stopped and not while it is running.
Thanks for help
(3,440 Views)
You can change visible items during runtime for Graph and Chart indicators.
It seems to me that you have connected a custom context-menu with the graph in the project where it doesn't work as expected.
Norbert
Norbert
Expert: Geometry
(3,436 Views)
Accepted by topic author OnlyOne
Or maybe you have unchecked the "Allow default run-time shortcut menus" in the Customize Window Appearance?
(3,434 Views)
Thank you very much sandal.
This was the problem.
Smiley Happy
(3,428 Views)
