Ring Item Change
How can I cahnge Ring item by keyboard input
For example
Ring Initial as follow
Item       Value
AA              1
BB              2
CC             3
DD             4
when i choose "BB",then i enter "EE"
Ring will change to
Item       Value
AA              1
EE              2
CC             3
DD             4
but everytime I click on Ring,always show the Item List,so that i can't change the value.
I've try "Prompt User",but it will popout a new window,
Thx for your reading, and sorry for my poor english
(3,355 Views)
I don't know of any way to do it with a built in feature. But I think this gets your desired functionallity with a combo box...
(3,335 Views)
You can easily do that by using the "Strings" property of the Ring control. Select the item you want to replace with a new Item and have the item in a String control. So you can have an update button, once it is clicked use the replace array subset primitive to replace the item with the new one.
(3,325 Views)
Thx for
(3,312 Views)
The ring controls have a U16 data type. They're generally meant to index a list of real world things, so that you can select array entries using a term that a person would understand as opposed to a number. They work great in state machines to name the different states. Of course they have many properties and can be modified at run time so end up being more flexible than this. The combo box has string data type. Internally they work on key, value pairs that you can access through property nodes. So they are more like a dictionary. They can have a list of pre-defined strings which the user can choose from, but the user can also enter an out of range string. You can leverage this feature to create the control I think you're trying to create, where the pre-defined list can be easily edited by the user, but the user can't enter out of bounds values.
This would make a great X-control which had U16 data type to look like a ring, but have the behaviour you desire!
(3,280 Views)
Not necessarilly. Ring control can have different data type even DBL and also you can set any value to a selection. If you haven't created the Ring control/Indicator don't use it straightaway without knowing the values of the list, since it may not be sequential.
Actually Enumerated data type is generally used in State machines.
(3,271 Views)
