Ring and Enum value in event structure
Please, explain me how does data transfers to an event structure from outside?
There is an example with ring and enum controls that shows that if you try to get value of control by connecting control output to an event structure than you are getting previous value! How is it possible and what is made for?example.png
(3,676 Views)
Accepted by topic author Prain
That's exactly what you'd expect. If you run it in highlight mode it might be clearer. The Enum and Ring controls will be read as soon as possible, then the Event structure will wait for a value to change. So whatever will happen inside the structure the outside values will already be 'old'.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,650 Views)
Thanks. I thought it works in a different way... Execution Highlight explained everything!
(3,638 Views)
