Ring constant type def not updating LabVIEW 2010 SP1
I have an issue using LV 2010 SP1 with updating of ring control constants.  If I modify the values or item names of a ring control that is type defined (type def or strict type def) my block diagram constants do not update.  The constants are set to Auto-Update from type def and if I right-click on the constant, change it to a control, and then back to a constant, they update just fine.  And if I have a control/indicator on the BD it also updates fine.
Anyone else seen this issue or can someone attempt to duplicate?
LV 2010 SP1 bug?
Dan
(4,456 Views)
Accepted by topic author DBerry
It's not a bug. See here - http://digital.ni.com/public.nsf/allkb/46CC27C828DB4205862570920062C125
___________________
Try to take over the world!
(4,450 Views)
OK, thanks for the reply.  I'm surprised I haven't come across this issue in the past.  I think I will use an enum and disable the items with unwanted values.
Dan
(4,424 Views)
