Ring text to Sql Query
hi need help. i have problem to call the values of the ring  to call to sql query.
Example the ring values : A22222, W23333,.....
the query i used is Select StationNum,StationName,Temp from StationLog where StationNumber="ring values( A22222, W23333,....)";
i need to pass a value of the ring text at once. What method i can use?
(3,031 Views)
Hi jeyanthi,
i´m not sure if this is what you asking for, but if you want to have all ring elements in one string, then try this.
Hope it helps.
Mike
Message Edited by MikeS81 on 05-13-2008 07:43 AM
(3,026 Views)
It seems to me that you should really search for some SQL tutorials and books. Your SQL query doesn't seem to make any sense and you won't really make any progress if you ask about every single thing.
___________________
Try to take over the world!
(3,014 Views)
