Rise flag TRUE if at least one value in ARRAY is TRUE
I have a BOOLEAN ARRAY out off a FOR LOOP.
I want to turn an INDICATOR LIGHT ON if at least one value in the ARRAY is TRUE.
(4,272 Views)
Or Array Elements is on the Boolean palette.
(4,272 Views)
On Tue, 12 Feb 2002 09:10:07 -0800 (PST), Dennis Knutson
Oo! That's much better!
(4,272 Views)
Thanks!
That's what I'm after for.
Felix
(4,272 Views)
>ARRAY is TRUE.
This might be a bit round-about, but...
1. Convert the boolean array to a numeric array
(Func>Boolean>Boolean to (0,1,...))
2. Sum the numeric array
3. Test the sum as GT 0
4. Pass the result to the indicator boolean.
Ben
(4,272 Views)
Thanks Ben,
I've been going in the same direction.
Felix
(4,272 Views)
