Robotics Simulator Mass Problem
Joel;
I have converted it to VRML File.
I will be waiting for your answer hopefully.
Thank you
And also happy new year
Dinçer Saygılı
Acrome Robotics
Istanbul Technical University
ARI-3 SciencePark
Message 11 of 19
(2,619 Views)
Hi dncr,
I think it could be possible that the simulated motor is not generating enough torque to turn the link.
Joel I.
Message 12 of 19
(2,585 Views)
Dear Joel;
I know that the torque is not enough to rotate the yellow link.
I have already tried to explain it from the begining.
I want to control the torque of the motor. If it can be controlled, the whole robot system can be controlled.
If the torque can not be controlled, the simulation becomes almost meaningless and loses its reality.
There must be a way to control it.
I think you got the what the problem is now.
Please show me the way to control the torque of the motor.
Thank you
Dinçer Saygılı
Acrome Robotics
ARI-3 SciencePark
Message 13 of 19
(2,572 Views)
Joel;
I want a similar VI with that Simulink Block in Matlab,
It is called Joint Actuator
Here is official information about it.
http://www.mathworks.com/help/physmod/sm/mech/ref/jointactuator.html
With this block, I am able to control the torque(or force for prismatic joints)
so I can simulate the system for real masses.
Thank you
Dinçer Saygılı
Acrome Robotics
ARI-3 SciencePark
Message 14 of 19
(2,563 Views)
dncr,
I have not been able to find a VI that directly allows you to control torque.  I'll keep looking to see how you would do this and keep you posted.
Joel I.
Message 15 of 19
(2,544 Views)
Joel;
Thank you very much for your help.
I will be waiting for a solution of this problem.
Best regards
Dinçer Saygılı
Acrome Robotics
ARI-3 SciencePark
Message 16 of 19
(2,529 Views)
Hi dncr,
It looks like you were able to obtain a solution in this forum thread?
http://forums.ni.com/t5/LabVIEW/Controlling-Setting-of-the-Torque-of-a-Motor-in-Robotics-Module/m-p/...
Joel I.
Message 17 of 19
(2,497 Views)
Dear Joel;
Yes, this topic belongs to me too.
But, in fact, I gave up.
I will use another environment for simulation.
Thank you for helping me.
Dinçer Saygılı
Acrome Robotics
ARI-3 SciencePark
Message 18 of 19
(2,489 Views)
hi
i need a block diagram which permits to create a file .xml ( for example the labview code which creates scenes shown in pictures below ( these pic are taken from the help of labview robotic module)
thanks
fig 1fig 1fig 2fig 2
Message 19 of 19
(2,219 Views)
