Robotics
i was work on equations for arm 6 dof and there is something wrong and i don't know why ....?!error.PNG
(3,281 Views)
You are doing calculations on double precision float numbers. Why do you declare your variables as integers (int)??? Change the "int" type declaration at the first two lines into "float64".
I could not check your code for other errors like mistypos, since you posted a picture and not a VI...
(3,262 Views)
