Rohde&Schwarz SGS100A Control Using LabVIEW
I want to control phase of the R&S SGS100A RF source using LabVIEW. But I have a phase stability problem. It's not just phase stability problem, the signal which are generated using sgs100a are not stable as produced using R&S SGMA-GUI. We have also 10 MHz common clock in our system. You can find my design in the attachment. I think there is no example in the R&S and Labview about sgs100a.
(1,717 Views)
Hello!
I don't have SubVI blocks of the program.
Can you share and send SubVI blocks of the program?
zhukov@bms.tel
(994 Views)
