Roll back to previous revision
Is there a way to rollback a version of a VI to a previous version if, for example, a bug is found and the previous version of the VI is wanted?
(2,968 Views)
No.
Always keep backup !
(2,967 Views)
Only if you have a source control system in place.
-Matt Bradley
************ kudos always appreciated, but only when deserved **************************
(2,963 Views)
It's trivial if you are using a source code control program. Look into the open source program called Subversion.
(2,961 Views)
