Root Directory Path to SubFolder Directory Path
How do I select a Root Folder Path and pumps only with the path of the subfolders that is inside of the root folder before it goes into the while loop.
(2,996 Views)
Accepted by topic author saintalan94
Hello saintalan94,
use the "build path" node from the file palette inside the while loop.
Greets, Dave
(2,991 Views)
