Rotate Plot Legend of XY graph
Is it possible to rotate the plot legend so the letters of the plot names run from bottom to the top rather than across the operator interface?
The names for my plots are bigger and I need to show at least four plots at the same time. Putting scales to the right/left/above or below without rotating may cause a shorter XY graph!
Any ideas for me?
Regards
K Waris
(2,992 Views)
Accepted by topic author K.Waris
I don't know if there is a native way to do it, but you can "cheat" to do that:
You can move the array where the legends are, or even make the array grow into lines instead of column.
Is the idea ok for you?
Giuliano Franchetto
Student at the l'Ecole Nationale Supérieure des Mines de Saint-Etienne, cycle ISMIN (FRANCE)
(2,979 Views)
Surely an elegant approach!
(2,939 Views)
