Rotate a circular image
I would like to be able to display a circular image, which can then be rotated. The image is typically of a valve for controlling the flow of liquid. I need to be able to display its current position between 0 and 359 degrees with respect to its input/output ports. As most images are rectangular, can a image be laid onto a circular tool such as a dial so as to only display the circular section. I understand it is possible to rotate tools. I am currently using LabView 8.5.
Has anyone any experience of rotating images or masking an image for a circular representation?
(4,367 Views)
In reply #14 of the Picture Control thread Christian showed us how to rotate an image.
Rather than deal with the tedious work of masking around the circle I suggest you place a decoration with a transparent center region over the rotated image and just let the region of interest show through.
Ben
(4,364 Views)
It's not very tedious. 🙂 Simply check for the radius and substitute the background color if a pixel is outside the circle.
Here's a very rough draft modification of my old VI. Modify as needed.
Message Edited by altenbach on 06-03-2008 06:45 AM
(4,346 Views)
Yeeeeshhh....
Reminds me of the first time I road out a huricane and we came up with the bright idea (NOT) of measuring the ships angle of rocking by hanging a pendulum from the ceiling. I had never been sea-sick before that or since (amusement rides excluded).
Ben
(4,338 Views)
Ben, you're  not the only one to use this pendulum idea!
Phoenix Lander - Telltale (or jokingly a weather rock)
Message Edited by pbrooks100 on 06-03-2008 09:11 AM
(4,333 Views)
Many thanks for your suggestion I will try it. What package did you use to create a transparent centre circle?
(4,321 Views)
PowerPoint or any other package that will save as ".wmf", but first try Christian's example.
Ben
(4,317 Views)
