Rotate an object inside block diagram windows
perhaps it may be a stupid question, but can I rotate a block diagram
"object"?
How can I do it?
Thanks in advance.
*SkyBlueSeeker*
(7,585 Views)
Block Diagram objects generally have a particular orientation for a reason: inputs go in to the left, output flow out of the right. So to answer your question: no, you can't rotate them.
cheers,
Christopher
Christopher G. Relf
Certified LabVIEW Developer
Christopher.Relf@mBox.com.au
International Voicemail & Fax: +61 2 8080 8132
Australian Voicemail & Fax: (02) 8080 8132
EULA
1) This is a private email, and although the views expressed within it may not be purely my own, unless specifically referenced I do not suggest they are necessarily associated with anyone else including, but not limited to, my employer(s).
2) This email has NOT been scanned for virii - attached file(s), if any, are provided as is. By copying, detaching and/or opening
attached files, you agree to indemnify the sender of such responsibility.
3) Because e-mail can be altered electronically, the integrity of this communication cannot be guaranteed.
Copyright © 2004-2026 Christopher G. Relf. Some Rights Reserved. This posting is licensed under a Creative Commons Attribution 4.0 License.
(7,585 Views)
