Rotate overlapping images with transparent backgrounds 360°
I’m trying to build a .vi where I will simulate an airplane carrying a container. One knob will control the airplane rotating 360° on its own axis, and another knob will control the container rotating 360° on its own axis as well.
My difficulty is making the transparent .png images rotate 360° without losing their transparent background.
Thank you very much.
(130 Views)
Hi sozo,
Suggestions:
  • Use a 3rd party tool to rotate those PNGs with transparent background.
  • Prepare images for each 10° of rotation (makes 36 images), so you don't need to do that part every time: just display the corresponding image for each rotation value. (Change the numbers according to your requirements.)
(118 Views)
