Rotating Intensity graph ;-)
Is it possible to make an intensity chart or graph acting verticaly ?
So, The time axis (or Y axis) would be vertical instead of horizontal ?
Or, if you want, inverting the X and Y axes ?
Am I clear ? 🙂
M.G
(4,879 Views)
use transpose array
M. Gaillet ÐÉÛÅÔ ×
ÓÏÏÂÝÅÎÉÉ:393f9200@newsgroups.ni.com...
> Am I clear ? 🙂
> M.G
(4,878 Views)
Sorry I wasn't clear enough 🙂
I would like that ON THE SCREEN the intensity picture SCROLLS from up to
down, instead of from right to left !
M. G
"Kulaev Yuri" wrote in message
news:393f9f39@newsgroups.ni.com...
> use transpose array
> M. Gaillet ÐÉÛÅÔ ×
> > Am I clear ? 🙂
> > M.G
(4,878 Views)
Was this query ever answered? I am trying to do a similar thing.
(4,674 Views)
Hi JeffV,
I've attached an example showing the y-scrollbar property which allows control of the vertical scrollbar.
Also, Can a Waveform Chart in LabVIEW Scroll Vertically Instead of Horizontally? shows the theory behind a continually updating vertical scrollbar. In essence, they remove the oldest point and input the newest point at the end.
Cheers.
| Michael K | Project Manager | LabVIEW R&D | National Instruments |
(4,654 Views)
