Rotation of a 3D object
Hi
I am using LV 2013. I want to perform 1 deg rotation of a 3D object 360 times with resp to x & y axis.
For each 1 deg rotn of object wrt x axis, i need to perform 360 rotations of rotated object wrt y axis.
I use 2 nested for loops for this purpose. Whenever I try with small loop counts I get rotation about one axis only. When I use loop count 360, I get rotation about one axis only and after some amount of iteration it shows some error.
Please take a look at my VI
Thanks in Advance
Vishnu.T
(2,836 Views)
The setup window.vi should be placed outside of the loop. Then, pass the reference wire and create one shift register
PS: Uncheck the "Erase First" property of 2D Picture in FP.
(2,818 Views)
Thanks Jiddu I Got it correctly
(2,765 Views)
