Rotronic Humidity sensor
Anybody here with some expierence connecting these sensors via USB to
labview?
Thanks for help
Peter Tate
(4,701 Views)
> labview? Thanks for help Peter Tate
See:
http://forums.ni.com/ni/board/message?board.id=170&message.id=409220&query.id=534131#M409220
Also:
1) Page 3 of the following implies that they've used the Rotronic with Labview. You might try to contact the authors.
http://www.atmos-meas-tech-discuss.net/2/1057/2009/amtd-2-1057-2009-print.pdf
http://www.atmos-chem-phys.net/9/2959/2009/acp-9-2959-2009.pdf
2) Rotronic is using the Microsoft .Net Framework 2.0 for its USB driver and from the driver available on their website, they appear to be using the FTDIchip.com IC and driver.
http://www.rotronic-humidity.com/content/humidity_feuchte/software_drivers_tools.php
http://www.rotronic-usa.com/man/logger/Com-LogNT.pdf
Thus it is likely that their device just looks like a virtual serial port. Once their USB driver is installed, you could use the following to build your own interface:
http://decibel.ni.com/content/docs/DOC-8092
(4,670 Views)
