Router Web Page Authentication
See attachment, I've added all the header elements and removed the space as you directed.  The POST body returned is still:
<HEAD><TITLE>501 Not Implemented</TITLE></HEAD>
<BODY><H1>501 Not Implemented</H1>
The requested method is not recognized by this server.
</BODY>
I'll go back and look at the tamperdata again.  Thanks for the input.
Message 11 of 15
(1,693 Views)
I see I was missing part of the POST, the full entry should be:
POST http://192.168.0.1/ajax_request?Endpassword=admin Load Flags[LOAD_BYPASS_CACHE  LOAD_BACKGROUND  ] Content Size[-1] Mime Type[text/html]
Message 12 of 15
(1,689 Views)
In order to figure out what LabVIEW is submitting differently I used Wireshark to monitor a login attempt with my LabVIEW VI and again with Firefox, I removed the CR and NL to make it easier to compare.
Firefox login:
POST /ajax_request?Endpassword=admin HTTP/1.1
Host: 192.168.0.1
User-Agent: Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.9.2.13) Gecko/20101203 Firefox/3.6.13
Accept: */*
Accept-Language: en-us,en;q=0.5
Accept-Encoding: gzip,deflate
Accept-Charset: ISO-8859-1,utf-8;q=0.7,*;q=0.7
Keep-Alive: 115
Connection: keep-alive
X-Requested-With: XMLHttpRequest
Referer: http://192.168.0.1/
Cookie: lct_remember_me=; mac_remember=; lct_psw=; checked=
Pragma: no-cache
Cache-Control: no-cache
Content-Length: 0
HTTP/1.0 200 OK
Content-type: text/html
Date: Tue, 17 Mar 2009 15:32:24 GMT
Connection: close
LabVIEW VI login:
POST / HTTP/1.1
Host: 192.168.0.1
Accept: */*
Keep-Alive: 115
Cookie: ddddd=; dddddddd=; lct_remember_me=; mac_remember=; lct_psw=; checked=
Pragma: no-cache
Content-Length: 0
Content-Type: application/x-www-form-urlencoded
 I see a couple things wrong:
1. The LabVIEW POST VI is submitting the POST command AFTER the header in the LabVIEW POST, but Firefox submits it before.
2. The LabVIEW POST VI is adding "Content-Type: application/x-www-form-urlencoded" to the header, I didn't put that in there.
Message 13 of 15
(1,679 Views)
LabVIEW VI login:
POST / HTTP/1.1
Host: 192.168.0.1
Accept: */*
Keep-Alive: 115
Pragma: no-cache
Content-Length: 0
I'm not sure if the "Content-Type" header entry is affecting things or not, but I'm a bit suspicious of the beginning of the header. It's putting in
POST / HTTP/1.1
 I think that's where the POST should be, but it's putting it at the end. What happens if you put the POST function before the headers in the VI?
Caleb Harris
National Instruments | http://www.ni.com/support
Message 14 of 15
(1,667 Views)
Then I get the LabVIEW default header information.
POST / HTTP/1.1
User-Agent: National Instruments LabVIEW
Host: 192.168.0.1
Accept: */*
Content-Length: 36
POST /ajax_request?Endpassword=adminHTTP/1.0 501 Not Implemented
Date: Tue, 17 Mar 2009 17:18:19 GMT
Connection: close
The POST VI's block diagram is locked so I can't open it to see how these things are being appended, or to change the way they're being appended.
POST / HTTP/1.1
Host: 192.168.0.1
Accept: */*
Content-Length: 36
Connection: close
Message 15 of 15
(1,662 Views)
