Routing to an output terminal
Dear All,
Sorry for the earlier reiterations.
Page 20 of the NI CDAQ-9172 User Guide & Specifications:
Routing AI Start Trigger to an Output Terminal
You can route ai/StartTrigger to any output PFI terminal. The output is an
active high pulse.
I am using Visual C++ .  What is the API to connect or disconnect one internal signal to another?
If I use this as a trigger source and  route ai/StartTrigger to PFI0 for example, I expect an active high pulse at the PFI0 pin.  Is my understanding correct?
Thanks and regards,
A
Message Edited by angelmcdoggie on 04-18-2008 12:46 PM
(2,900 Views)
Oh I am sorry I cannot remove the iterations..That is my only question.  I only now realized that I misposted it.  It should be in the MSVC++ section.  Again sorry.
(2,891 Views)
angelmcdoggie wrote:
I am using Visual C++.
Please post here.
- Partha ( CLD until Oct 2027 🙂 )
(2,890 Views)
Hello All,
This post is being addressed in the Measurement Studio for VC++ forum here.
Matt Anderson
Hardware Services Marketing Manager
(2,846 Views)
