To properly help you, we need more information.
- What version of LabVIEW are you using? The WAV file VIs changed at version 8.0, and the change will mean a lot less work on your part.
- Define "huge". Is this 100kBytes of data? 100MBytes? 2GBytes? LabVIEW can handle any of these sizes, but the methods used will get progressively more difficult as the data size gets larger.
- Do you need to know how THD changes as you go through the data, or do you need a single THD value for the entire file?
- Is the file compressed in any way? If so, is it lossless or lossy? Note that lossy compression schemes, such as MP3, will cause distortion, so such files are not suitable for serious analysis. LabVIEW does not natively support compression on WAV files, so this will also cause extra work.
It appears you are new to LabVIEW, so I would highly recommend you work through the tutorials to learn the basics, if you have not already done so. The biggest thing to learn is that the best data buffers in LabVIEW are the wires, not the front panel controls, locals, or globals. LabVIEW is most efficient when wires, and only wires, are used. Sequencing of operations is determined by the data flow through the wires. Any node or subVI will execute when all its inputs are valid. Position on the block diagram does not matter. If you have two parallel sets of code on the same block diagram, LabVIEW will try to execute them truly parallel in separate threads or on separate processors (if you have them). This is why it is very important not to use locals, globals, or controls/indicators as data buffers unless you really know what you are doing. The parallel execution model makes race conditions very easy to create. Using data flow through the wires takes care of this issue. Experienced LabVIEW users rarely use globals and use locals only for GUI issues. The use of sequence structures should also be kept to a minimum. They, too, are rarely necessary.
Once you have got the basics down, look at the tutorial
Managing Large Data Sets in LabVIEW. It is an advanced tutorial, and relies upon some in-depth knowledge of how LabVIEW works. However, to successfully handle 100MByte+ data sets, you will need this information.
Good luck! Don't get discouraged. Once you know the basics, LabVIEW is a fast, efficient language for analysis programming.
