Run PC_Main.vi and cRIO_Main.vi automatically
I have my GUI on the PC an the data acquisition on my cRIO. My LabView project contains a main VI on the PC and a main VI on the cRIO. Until now, to start my program, I have to open the LabView project and then run each VI manually to make the whole program run.
Compiling my program to an .exe is not an option as I'm basically changing something every day. What is the most comfortable way to start my program (with as few clicks as possible)?
(644 Views)
Accepted by topic author UL-00
Hi UL,
When you want to run your "ever-changing" VIs inside the IDE then you need to run each VI "manually".
Once those changes are only to your host VI you may deploy an RTexe to your cRIO and set it to "start on cRIO startup". Your host VI/exe can connect to your cRIO RTexe using all the network communication functions you like to use…
(631 Views)
Since you haven't finalized your code and are still developing it, you can only open LabVIEW Development to run your changed code.
https://tmesystems.net/
(630 Views)
