Run Program in background
Hi
I know there is a post about this already in the newsgroup but I think I
need something different.
I need a way to make my program completely invisible to my users basically
have it running as a service. I can't for some reason remove the FP in the
app builder of my toplevel vi, I don't know why. And anyway, would removing
the FP in the app builder also remove the vi in the taskbar? Does anyone
know how to do this?
Jacob Thastrup
(4,038 Views)
Jacob Thastrup wrote:
> Hi
> Thanks
> Jacob Thastrup
Jacob:
I tryied to hide the front panel with labview application builder for linux
but it doesn't remove the front panel. I got this
in Linux, you must create a virtual frame buffer first and then send the
graphical out of labview to this virtual x-window.
For create the virt
ual frame, execute the following command:
Xvfb :1 -screen 0 160x120x16 &
with this you create a virtual frame buffer of 160x120 and 16 bits, then you
must send the application to this x-window:
Application -display :1 &
With this you can execute a program whithout graphical out and also you can
mantain in background with nohup command.
Ricardo Leal Pacheco.
e-mail: rleal@loa.alumnos.utfsm.cl/7111100@entelpcs.cl
FONO: (09)7111100, 654622.
INGENIERIA CIVIL ELECTRONICA U.T.F.S.M
(4,038 Views)
The program is for a Win2K/NT4 enviroment. I have never herd of a Win2K/NT4
command/program called "Xvfb". Do I need to use a different command or can
I send the display to another place?
Jacob Thastrup
rleal@loa.alumnos.utfsm.cl (Ricardo Leal) wrote in
<3A3A0D3D.9CE2A70B@loa.alumnos.utfsm.cl>:
>Content-Type: text/plain; charset=us-ascii
>Content-Transfer-Encoding: 7bit
>> Hi
>> I need something different.
>> basically have it running as a service. I can't for some reason remove
>> the FP in the app builder of my toplevel vi, I don't know why. And
>> anyway, would removing the FP in the app builder also remove the vi in
>> the taskbar? Does anyone know how to do this?
>> Thanks
>> Jacob Thastrup
>Jacob:
>linux but it doesn't remove the front panel. I got this
>For create the virtual frame, execute the following command:
>you must send the application to this x-window:
>can mantain in background with nohup command.
>--------------25B9B630C9B3D0B8D29F4A83
>Content-Type: text/html; charset=us-ascii
Hi
>I
>in the
>removing
Jacob Thastrup
>Jacob:
>the graphical out of labview to this virtual x-window.
>then you must send the application to this x-window:
>you can mantain in background with nohup command.
>--------------25B9B630C9B3D0B8D29F4A83--
(4,038 Views)
Shot in the dark; how about using the front panel as a splash screen and put
a pretty logo there, then use VI Server to hide the window? You could simply
use VI Server to hide it regardless, but I suspect the window will be drawn
and then hidden- so if you use it as a splash screen and make it look
intentional then it doens't look bodged.
Apologies if this has already been suggested and debunked- I've not paid too
much attention to this thread.
Jacob Thastrup wrote in message
news:9010ACFE0Jactbioimagedk@130.164.140.31...
Win2K/NT4
(4,038 Views)
