Run-Time Engine 7.0 and Excel
I found out that Run-Time Engine 7.0 running executable generated at LabVIEW 7.0 environment (code written in LabVIEW 7.1 but save as 7.0) cannot open Excel 2000 files. If I replace Excel 2000 with Excel 2003 application on my pc, the executable code will open the Excel file (Run-Time Engine 7.0 works with Excel 2003).
Is the Excel 2003 and higher versions will only work with Run-Time Engine 7.0 and higher code?
How can I make executables using Run-Time Engine 7.0 work with Excel 2000 (Windows 98 operating system)??? (I cannot change Excel and Run-Time Engine and OS versions due to limitations, how can I work with what I have?).
Thanks for your help.
LVLV
(2,791 Views)
(2,782 Views)
