Run Time Error During Shutdown
When I shutdown system, It displays error, MS VC++ Run Time Error. c:\Program Files.....Webserver/resources/access.log Application has requested run time to terminate in unusual way In event Viewer following errors are written Labview Info: Can not Listen on Http Port: 80 Labview Info: Can not open file ....Webserver/resources/access.log Labview Info: Can Not Open a Socket on Port: 80 Kindly help how to debug this error as soon as possible Regards
(2,763 Views)
Is LabVIEW running when you are shuting down your system when you are getting this error?  Also, does this happen everytime that you shut down your system or only after running a specific VI?
Justin Parker
Product Support Engineer
(2,729 Views)
