Run-Time Menu Insert items, increase indent level
I'm trying to add menu items programmatically in my application, it is possible to indent a new item? How?
Regards
(2,833 Views)
Accepted by topic author jchretien
If you want to add submenus to an existing menu, you can use the VI "Insert Menu Items" and add items under existing menu items. Otherwise, if you just want to indent the new menu, I would just add several spaces to the beginning of the item tags.
(2,803 Views)
Thank you, I realized my question was pointless as I didn't try before asking, the Insert menu items does what I need exactly
(2,793 Views)
