Run-Time Menu. Please, Please, Help!
Here is the weird thing that happens on my machine:
Custom menu normally appears in executable after EXE has been built. But
custom menu disappears from EXE if I move EXE to different folder or
install it using installer. No matter if RTM file is in the same LLB
together with main VI or added to application builder as a support file.
Otherwords run time menu appears only when I execute my application in
the same folder where it was originally built. If I move executable to
different folder, my run time menu disappears...
Please can somebody help me with that?
I have Windows98, LabVIEW 5.1.1 and NI-DAQ 6.6 installed.
Alex Suhisky.
(4,462 Views)
The only solution I have found is this:
In the Application Builder, you have to put "Destination Directory" and
"Support Files Directory" with the SAME DIRECTORY. By default, the .rtm
files (they are support files) search the support directory, so it is
necessary to put the same name for both directories.
I hope this solves your problem.
Miguel.
Alex Suhisky escribiÕ en el mensaje de noticias
38AD6F51.3A1BE28D@wpiinc.com...
as a support file.
> Alex Suhisky.
(4,462 Views)
When you move the EXE file, do you move the llb file too?
Eric
(4,462 Views)
hi alex,
   Is your problem solved?If so please post the solution as me too is facing the same problem
Thanks and regards,
srikrishnaNF
Srikrishna
(3,944 Views)
I doubt that you'll get a response 9 years later.
Which version of LabVIEW are you using?
Back then, he may have been using LV7.1 (at the latest), which means that how executables and installers were created has changed quite a bit.
Can you provide more description of what you have tried so far?
(3,928 Views)
(3,924 Views)
