Run-Time Menu
I'm new user for LabVIEW. Use the version of LabVIEW is 8.6
One problem describe as below:
Can Run-Time Menu and Event Structure exist simultaneously?
Without Event Structure, Run-Time Menu works well, but Run-Time Menu works abnormally.after adding Event Structure,
How do I modify the problem?
Thank you for your help.
Attached is the program.
(3,321 Views)
Hi kchuang,
      You might receive more help if you save your code for version 8.5 (some people haven't purchased 8.6 yet! Smiley Wink )
On your Main.VI, do File\"Save For Previous Version"
Cheers!
"Inside every large program is a small program struggling to get out." (attributed to Tony Hoare)
(3,287 Views)
http://forums.ni.com/ni/board/message?board.id=5170&thread.id=2035
(3,258 Views)
Thanks for your reply.
This issue has been solved.
KC
(3,232 Views)
