Run Time Shortcut Menu Separator Bug
(4,187 Views)
This was reported to R&D (# 43CGK1U4) for further investigation.  Thank you very much for the bug report.  If a possible workaround for this bug is found, I will repost to this forum.
Brian B
Account Manager
(4,160 Views)
The easiest workaround is to have one or many controls covering the entire pane and then the separators are diaplayed properly.
PJM
Message Edited by PJM_Labview on 11-14-2006 08:14 PM
vipm.io | jki.net
(4,145 Views)
