Run-Time Shortcut Menus
     How can i create Run Time Shortcut menu with tick mark?. like here i am attached the file.
Thanks in Advance.
Sivaraj M S
Sivaraj M.S
CLA
(4,483 Views)
Do you mean like Edit... ?
That is just 3 periods.
Or do you mean the right point triangle which is the indicator for a submenu?
(4,477 Views)
In Graph AutoscaleX is a default runtime menu. in AutoscaleX is coming the Tick mark. if i create other User menu tick mark is not coming. How can i get this tick mark in user run time menu.
Sivaraj M.S
CLA
(4,463 Views)
I guess you are looking for a custom run time menu when a control.indicator is right clicked?
See this example shipped with LV
"C:\Program Files\National Instruments\LabVIEW 2009\examples\general\Run-TimeShortcutMenu.llb\Run-Time Shortcut Menus.vi"
I ma not sure how to add symbols to this run time menus..Try searching NI
Guru
Regards
Guru (CLA)
(4,455 Views)
Hi Siva,
are you talking about the checkmark?
Read the help for "Set Menu Item Info" function and you will notice the "checked" input Smiley Wink
(4,438 Views)
Hi siva_usic,
 Look this..
Thanks and regards,
srikrishnaNF
Srikrishna
(4,414 Views)
