Run Time Zoom
How can I zoom in/out graph in run-time?
Simple graph is in attachment.
(4,313 Views)
You can set the scale ranges.
Jim
(4,296 Views)
Yes but its not exactly zoom. In labview we can use zoom tools when the vi isn't runing.
Also zoom options not used when vi is runnig in graphs palette.
I want use zoom tools while my vi runnig.
(4,285 Views)
Accepted by topic author keremgeliz
Hi keremgeliz,
just use those zoom tools also at runtime, no problem here with them…
On your snippet:
There is no wait in the loop: you are banging the graph as fast as your PC can…
AND: You have autoscaling enabled. How should LabVIEW act with enabled autoscaling when you try to zoom in and in the same time new data are to be displayed?
(4,269 Views)
Thank you GerdW.
Its fixed now.
(4,250 Views)
