Run VI Async cause TestStand "Hang"
I need a status window and a stop button for my test sequence.  So I launch the status window async, and use the TestStand modal VI to make it model to the sequence editor.  It works as planed: the stop button stops status VI and the loop in the sequence; the sequence execution finished, report show up.  The only problem is that the sequence editor becomes hang/disabled after that.  I found a workaround using Windows API.
Anyone run into similar situation?  What's the right way to create a status window?
I can't switch to the simply or advanced LabVIEW UI to to run sequence.  It's not my call.
TestStand 2017, LabVIEW 2018, Windows 10 Pro.
George Zou
(1,046 Views)
Accepted by topic author zou
The problem is the TestStand - End Modal Dialog.vi
Don't know why it fails to enable the Sequence Edit window when my status VI is launched async.
Since I have to use Windows API anyway, I'm going to use Make Window Always on Top.vi instead of the TestStand Modal VIs.
George Zou
(970 Views)
