Run a VI continuously
Hi Guys
I have prepared  a Vi n i am ure it has no errors but when trying to Run it by pressing RUN it only runs for 3 seconds and then stops running. but it works good when pressing run continuously. but the problem is that continuous running is not a normal way of  running a VI .
  Hope you can give me some help .
Any help would be greatly appreciated .
Thank you .
Bill David
Message 1 of 16
(4,834 Views)
Pleas Post the VI.  You did not give us enough clues.
Lynn
Message 2 of 16
(4,833 Views)
First Thank you for the very fast reply
Here is the VI  m talking about . (labview 2009)
Bill David
Message 3 of 16
(4,831 Views)
Are you seeing any error code in the Error Out cluster on the front panel?
Message 4 of 16
(4,825 Views)
No Bill.... :s  No Errors..m wondering what could it be ....
Thank you
Bill David
Message 5 of 16
(4,822 Views)
Well, if I disable errors, the VI doesn't stop until I hit the Stop button.
Can you provide a screenshot of your front panel after it stops?
BTW: You have a duplicate Stop button control that's not connected to anything.
Message 6 of 16
(4,819 Views)
Thanks Bill for reminding me abt duplication of stop button
And I know u wanna look at the error code of the output error . IT JUST GIVES NOTHING :s that's exactly wht bothers me !!!!!!!!!
Bill David
Message 7 of 16
(4,815 Views)
Accepted by topic author Bildavid
Unless someone else sees something I'm not...I can't think of a logical reason for the loop to terminate except for the two obvious conditions.
Message 8 of 16
(4,811 Views)
Dear Bill thanks alot for trying to give me some help . I appreciate that !!
Thank you .
Bill David
Message 9 of 16
(4,807 Views)
One more thing Mr.Bill, n i hope you can help me too
 what do you suggest in this case ?
I have a signal to be displayed using waveform graph. ( I am acquiring a real time signal ) All i want to do is to see this signal moving from right to left keeping data updated but without letting me see the old pieces of the signal ( Just like in ECG monitors ) .
 I have tried to to enable and disable autoscale on both X axis and Y Axis . I tried everything but nothing revealed . it keeps making me see the old  displayed data + the signal that is updating . :S I have posted this question more than 5 times but no one seemed to have exact answer .
Thank you .
Bill David
Message 10 of 16
(4,804 Views)
