Run a VI in real time without a delay
I would like to communicate in real time with a sound level meter via serial port. I've already created my program but still I have a delay of 3 seconds, it  maybe not important but I do have to remove it for my application.
Is there any possibility to delete completely the delay?
Just for information, my Vi contains two local variables, could it be the reason? Or maybe because a certain timeout of the serial port?
If you need to see the program, just tell me.
Thank you in advance for your help.
Message 1 of 25
(4,580 Views)
Yes, attach an image of your code. The 3 second reading does sound like you are getting a timeout. You get a timeout if you request too many bytes or you have enabled the termination character and the instrument does not send one or the one it does send does not match what you have programmed.
Local variables are usually just badly written code.
Message 2 of 25
(4,575 Views)
Thank you for your reply.
Here is a snapshot of the first frame of my sequence and the control panel of the program.
Message 3 of 25
(4,527 Views)
Actually the best thing is to post the actual VI.  The next best thing is a snapshot of the block diagram.
Can't really tell anything from the front panel.  Are you talking about the dip?
Bill
CLD
(Mid-Level minion.)
Message 4 of 25
(4,520 Views)
The only thing I can say about your attachment is pretty ugly colors.
Message 5 of 25
(4,513 Views)
Maybe it is being developed for a young girl who likes pink/purple...or a guy, not that there is anything wrong with that.
Message 6 of 25
(4,485 Views)
Local variables are one of the fastest data transfer method.
But you should use them very carefully.
by  real time do you mean if you are sending some command then you should get reply within certain predefined amount of time??
Message 7 of 25
(4,478 Views)
Doubtful but they are probably not needed.
You still have not shown any code. You do mention a sequence. A sequence structure is another hint at a bad architecture.
Message 8 of 25
(4,473 Views)
Actually, I would like to receive the data from the instrument exactly at the same time it displays it on its own screen.
I'm using a stacked sequence, because I have two loops and I want that one runs before the other.
Message 9 of 25
(4,457 Views)
I think we either need to see code (or even a picture of the block diagram) or discontinue the discussion.  It's like trying to diagnose what's wrong with a car but the owner won't let you near it.
Bill
CLD
(Mid-Level minion.)
Message 10 of 25
(4,444 Views)
