Run a labview GUI without Labview installed
When i try to build the installer, it says it cannot find the Visa path. However VISa is fully installed on my pc.
When installing the Labview runtime engine separately, should I also be installed Labview Visa runtime?
Message 11 of 15
(1,828 Views)
Hi lolasue,
as your EXE needs VISA you need to install it - either by setting up an installer or by "manually" install the VISA runtime!
Then something went wrong while/after installing LabVIEW.
Did someone "clean up" your PC and removed the installation packages needed by the AppBuilder?
Message 12 of 15
(1,822 Views)
Yes you need to include VISA Runtime also: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019LRFSA2&l=en-US
uday
Message 13 of 15
(1,821 Views)
So my Client needs to install Labview Runtime Engine and also Labview Visa Runtime?  The application will then find both to run on their pc?
Message 14 of 15
(1,814 Views)
When you add both to installer then it will automatically installs the Runtime engines.
uday
Message 15 of 15
(1,811 Views)
