Run a test sequence from a VI
I would like run a test sequence from a VI but I don't know if it's possible and how we do it.
I edited the test sequence via Teststand. Do you have any tracks/example ? because I am a little lost.
(1,459 Views)
There is an example for that in TestStand (Version)> Examples>TestStand API> Executing Sequences Using API> LabVIEW. This should be located in the Public Documents folder for all users in more recent versions of TestStand.
Now Using LabVIEW 2019SP1 and TestStand 2019
(1,419 Views)
