Run more than one asynchronous Vi in subpanels
Hi All,
I'm trying to run the same template Vi, asynchronously, more than one (3 times) in 3 separate sub-panels, all with different data being passed to them. So far I've got this:
The first sub-panel displays correctly, but the other two fail on Error 1145. Where am I going wrong? I've been following some guides for loading sub-panels, but I can't find much info on running multiple asynchronous sub-panels that use the same template Vi.
TIA
(3,654 Views)
Accepted by topic author Lbee11
Try one open for each subpanel.
Ben
(3,641 Views)
What Ben is getting at is that you are trying to run the same instance of the VI 3 times.  You need to open 3 difference instances of the VI to run them in parallel.
(3,637 Views)
Thanks, been a looong day! Seems so obvious now
Also need to remember to close the reference, running this continuously opened a lot of vi's... a lot
(3,629 Views)
