Run sub VI in another VI
I have a subVI and I want to run in another VI. As you see in the attached file, subVI can not receive any parameter from UsingVi.vi. How can I fix the problem?
(5,296 Views)
Accepted by topic author Mmehrabin
Why do you have a loop in your sub-vi?
How do you plan on stopping that loop?
Remove the loop from your sub-vi and put it in your top level vi.
=== Engineer Ambiguously ===
(5,291 Views)
Your subVI has  a while loop that can only be stopped by hitting the stop button, which you can't hit because the front panel of the subVI is closed.
The loop belongs in your main VI.  The subVI should not have a loop.
These are all basic rules of LabVIEW's dataflow.
I would recommend looking at the online LabVIEW tutorials
LabVIEW Introduction Course - Three Hours
LabVIEW Introduction Course - Six Hours
(5,290 Views)
In my subVI I need a shif register. Without the while loop how can I implement the shift register? By feedback node?
(5,227 Views)
What you showed doesn't have or need a shift register in the subVI.  It is a simple subVI that behaves like a function.  Take inputs, make calculations, send out the outputs.
If your subVI does more  than what you showed, then:
You can put in a feedback node.
You can put in an uninitialized shift register on a while loop, and use a True constant wired to the stop terminal.  This is also know as a functional global variable or an Action Enginet.
Or put the shift register on the while loop in the main VI.  Pass your array or data into and out of the subVI>
(5,222 Views)
Thank you  so much. It fixed.
(5,159 Views)
