Run sub-vi in background
I have a main vi which calls a sub-vi.  The sub-vi requires user interaction and then performs some time intensive tasks.  Is there a way to have the sub-vi run in the background after the appropriate user interaction, allowing the main vi to proceed in its operation (not wait for the sub-vi to complete)?  I have tried setting a self-reference in the sub-vi to hide the front panel, but this does not allow the main vi to proceed, i.e. the main vi still waits for the sub-vi to complete before continuing.
Message 1 of 8
(4,826 Views)
you are using only one while loop in your main vi, right?
to do what you want, i use two or more loops (while loop and/or timed loop), and then exchange data between loops with global variables to call your subvi
i hope it helps 😉
Message 2 of 8
(4,817 Views)
Using two while loops does not seem to work.  The loop containing the sub-vi will not run simultaneously with the main while loop which means that the sub-vi doesn't get called until after the main loop has completed.  There are no wires connecting the two loops.  Is there a more robust way to accomplish what I want?
Message 3 of 8
(4,810 Views)
This is something I also wish to achieve The closest I have gotten is using projects and Classes
- there is always an easy way, but it is always the hardest to find
Message 4 of 8
(4,804 Views)
I don't understand the problems you are having. Running two separate while loops has worked for as long as I have been programming in LabVIEW. Please post some code that demonstrates what you have tried and doesn't work.
Message 5 of 8
(4,798 Views)
here is my example using a projext and class
Message 6 of 8
(4,795 Views)
Further improvements
PS make sure to change path constant on the in C.vi to where you have A.vi saved
Message 7 of 8
(4,783 Views)
I apologize; it does work.  I had messed something up on my first implementation of the two while loops.  This solution works very well in conjuction with the sub-vi property FP.state set to hidden.  Thanks.
Message 8 of 8
(4,770 Views)
